Our shower has started to cut out. After being switched on it runs for about 5 secs then stops, but will comtinue to run if you hold the start/stop button in.
I think it's probably a switch fault and was wondering if it's easy to replace? I've had the cover off, but the latched switch seems to be integral/attached with the flow assembly etc. Do I need to take it all out to replace or does it come away with the rest in situ?
Many thanks, TT
Many thanks, TT
