- Joined
- 23 Nov 2003
- Messages
- 3
- Reaction score
- 0
- Country
I wish to install a light circuit that is two way controlled and that can also be controlled be a motion sensor that can be turned on or off from two locations.
The sensor would be mounted on a garage and control a set of entrance lights leading to the front door of the house. The lighting circuit should be set up so that it can be operated manually (independent of the sensor) as a two way lighting circuit (one switch inside the garage and the other inside the house) but we also wish to be able to choose to have the circuit controlled automatically by the sensor. It would be adequate to turn the sensor on or off from inside the house only but would be preferable to have 2-way control of the sensor (so that it can be turned on or off from either the garage or from inside the house).
Can this be achieved and if so, how?
Regards
Regards
