Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Having connected power to my motion sensor I cannot get any power from the "Lout" terminal. Is this a fault with the sensor or am I doing something wrong
your post is slightly vague , for help Id suggest advising us exactly how you have wired it i.e. what cables you have at the sensor and where you have wired too..a pic can be useful too...
It's a Kanlux Merge JQ-O sensor with three terminals. Lin, N and Lout. I have connected the positive and negative leads from the power supply to the Lin and N terminals respectively but the Lout terminal remains dead.
you need a cable in l out which would be a switch live to the light ....
generally when wiring sensors due to the limited space for cables you would take a 3 core and earth flex/pvc t&e , the 3 cores would be switch live lout, permanent live l in and Neutral N...
The sensor Lin/Lout terminals act as the switch.
If you are using T&E then the brown cable supply live should go in the Lin
and the blue cable supply neutral should go to the N.
The T&E leaving the sensor going to the light should be wired brown load live to Lout and blue load neutral to the N terminal.
So two blues in the neutral.
I am assuming this is a 230V AC (mains) powered device?
If so, please note that there are no positive and negative connections in AC circuits. You'll find positive and negaive in DC devices like batteries and torches.
In AC (alternating current) your connections will be live (aka line) and neutral (plus an earth connection, of course).
EDIT: More thoughts.
How are you testing that no power is at the Lout teminal. You need to check between Lout and Neutral using a test meter. Also check you really do have power in on the L and N terminals, again, using a test meter.
Another thought. Your detector will not work in daylight unless you move the LUX adjustment to the "Sun" position. If its on Moon then nothing will happen until its dark!
I think taylor two cities has hit the nail on the head, It was my first thought. if the lux is not set to the sun position then there will be no voltage to the L out.
