mounting a wall hung wc directly onto tiles - ok?
26 Jan 2010
Yorkshire
Hi, I'm mounting a wall hung WC onto a frame. The wall it is butting up to has been ceramic tiled. Will the WC be ok mounted directly to this surface or should there be some kind of padding/silicone between the two ceramic surfaces? - Bit scared of breaking the tiles. Also how tight does one tighten the bolts?
