hi, my father has just had a new grant oil fired combi boiler installed, all has been well for week or so but all of a sudden when it heats the hot water there is now what sounds like air in the system. the noise kind of surges through the circulating pump but its not continuos, sounds every 8 secs something like that. when you switch off pump/boiler it stops instant. the system has auto bleed valves with the black screws about 1 turn undone. if you run both the central heating and hot water its fine?? no noise. its only noisey when heating hot water. Any help greatly appreciated.
