Hello,
I have had gas central heating fitted this week with a Worcester Greenstar 28i junior being fitted. I have found however that the boiler seems to be very insensitive to the hot water flow. When I turn on the hot water tap you can get a little hot water for a while (I believe being left over from the last time you got the boiler to turn on) but eventually runs cold. The burner does not turn on and the green light stays off.
If I turn the tap on very heavy, the boiler will come on and heat up the water.
If I then reduce the flow again but keep it running the water runs cold again eventually and the burner does not come back on. When I say reduce the flow, I don't mean to a tiny trickle either, it's still a decent flow.
What is likely to be the problem? My installer is coming to finish a few bits and pieces of the job on Monday what should I expect him to do to fix this?
I'm a little worried as I've been a bit unhappy about some other aspects of the work he's done.
