Got a Gledhill Boilermate 2. On top of the main tank is a small tank with a ballcock system in it. Ever since I shut off the water to fix a radiator, this small tank is forever refilling, 24 hours a day and its noisy. Its keeping me awake at night.
What the hell have I done and how do I fix it?
Found this description of boilermate so guess its the FE tank I'm on about:
Gledhill Boilermates....
Boiler provides heat into flow and return pipes with three way valve and pump as normal. Output of three way valve is cylinder (heatstore) or CH. If Heatstore needs heat threeway valve sends heat to store. If CH needs heat and store is full three way valve can send heat from store to CH. If store is low three way valve sends heat to CH and store. The function of the pump and three way valve is controlled by PCB.
Now for the DHW part. This is a seperate area with own pump and on early models own PCB. Turn on DHW tap, flow detected by flow switch. DHW Pump starts to send heat around heat exchanger mains cold goes thro other side and heats. Exit sensor detects water temperature and controls speed of pump to keep DHW down to safe 57c temperature.
No mains water goes to cylinder hence no need for pressure vessel etc. Heatstore has small FE tank on top for boiler as normal.
Good technical support from Gledhill.Also good manuals. Min problem with the system is setting up boiler to store. Boiler must be set to MAX. Setup tunes store to boiler output so that boiler doesnt ever overheat.
