Hi.
I’ve got a problem with my mum’s central heating. The pump is making a humming noise that is very annoying. All the radiators heat up fine so my mum won’t get an engineer in. I’m just worried that something may go wrong. It was happening last year but not as bad as now.
I have bled the radiators and I find that one particular (upstairs) radiator needs bleeding every so often, which I find strange, as there must be air in the system, which is moving around to this point. I have done this in the past with the heating switched on. I am led to believe this can introduce air into the pump, and that could be why it is labouring so much. I have removed the slot head screw from the front of the pump and a trickle of water comes out. Should I conclude then that the bearings are worn? The pump is set to its highest speed, any slower and it really struggles.
I was reading a thread on this forum where the person with the problem was asked the following questions that seem relevant to this situation (but they did not reply)
1. Does the highest radiator bleed differently to the others?
2. What colour is the liquid?
3. Is the pump higher or lower than the highest radiator?
My answers are
1. One radiator seems under higher pressure. Air, then water sprays out.
2. The liquid is clear at first then turns black.
3. The pump is slightly higher than the rads.
I have tested the f & e vent with a jar of water. The result was; when the heating was switched on about 1/3 of a cup of water was sucked up the vent then released 2-3 seconds later. When it was turned off air bubbles were forced out (about the same capacity).
Hopefully this information will mean something to somebody. Please let me know if you have any advice.
Details of system-----
10 or 12 years old
Ideal Classic LXFF & FF fanned flue gas boiler
Grundfos super selectric 15-60 pump
9 rads (5 up & 4 down) 30 years +
My answers are
10 or 12 years old
