Ocean Alpha 240eco help
14 Jan 2008
Leeds
I've already been told that the boiler I have isn't great, and I know the fan is going, but its what I have as I've just moved into a new house.
The boiler works fine, but does not seem to go off on a night when the timer is turned off. It's got a remote clock and thermostat. The boiler continues to fire up through the night although its set to be off? Checked the clock/thermostat and otherwise it works fine.
On the boiler where the timer would be if it was inbuilt there is the cover panel with a red flashing light on it - not sure if it should be doing that or if that indicates a fault - it's being doing that since I moved in.
Any ideas?
