This is a house I know very little about, other than it is 10 years old.
Just had central heating engineer out to check that my system is working correctly.
He said the boiler is in perfect working condition and switched the system on full. When I checked the radiators all were producing heat to varying levels of satisfaction. When I say that, the Kitchen radiator was not a hot as I would have expected, but in one of the bedrooms it was scorching hot, the rest were somewhere inbetween.
However the newest radiator which is in the extension of the house built 5 years ago has an issue. This is the only radiator in the house to have a thermostatic valve (ie settings 1 to 5, and operates by pin being pushed in and out). Heat could be felt from one of the pipes that fed up to it but the other one was stone cold. Of course this meant the radiator would not heat up. The engineer said "there was a blockage in the radiator". When I asked if he could fix it, he said there is no gurantees but any one of the following could do it:
1) Replace valve on radiator (on the pipe where it is cold) - approx £65
2) Replace radiator - approx £170
3) Flush entire system - approx £450 (takes all day)
After he left, I switched off the central heating at which point a tiny bit of heat was felt at the top of this 'cold radiator' - odd
I really need the entire system to work.
Advice please...
Advice please...
