Hi Guys
Can anyone please help me. We have had a new boiler fitted and radiator thermostatic valves. The plumber drained the system and flushed it out before fitting. Everything worked for a couple of weeks then we noticed that the radiator in the hall that dosesn't have a thermostatic valve on it is not getting hot. The boiler a Worchester Greenstar cut out a few times so the boiler people came and checked it saying it worked ok. British gas came and put a new pump in and said that the system needed a Powerflush (?). The plumber says its ok and doesn't need it. Is there anyway I can check if the system is blocked and if it is unblock it. I'm a bit stuck as nobody wnats to help me out.
