Hi all
Once again my CH has stopped working, but I still have HW.
Pump running ok, HW comes on when called and fires the boiler. CH does not come on or fire the boiler when called.
I installed a new mid position valve in August, and the system has worked fine until two days ago when the CH cut out.
I managed to get the CH going by placing the valve in Manual, but the lever won't stay in Manual and within 10 minutes has set itself back to Automatic and it turns the CH off in the process.
I had the HW and CH set to timed last night, and both came on this morning and the CH ran until the time-off setting.
I've now selected CH on (permanent) and nothing. Boiler not firing.
I've also tried switching the HW on as well as CH to see if the CH is being called only when HW is, but that hasn't worked either. The pipe from pump to valve is hot, as is pump from valve to HW. Pipe to CH is cold.
I can't believe the mid-position valve has packed up already (after only 3 months)
If there is an airlock or sludge in the system, could this be causing the issue? And how can I force the CH on?
Thank you for your help,
Tom
Tom
