Opel Vivaro 2.0 CDT
5 May 2009
Kent
hi
i have the above van but the wipers do not work upon investigation the right hand side arm has come off of the motor(under the engine) is this an easy fix it seems tight i can see where it shouls go but it did not deem to clip on
thanks to anyone that can help
Usually a ball and socket. Can you see the ball on the motor arm? If so push the socket back onto the ball. It will, or at least it should be a tight fit.
Not sure why it fell off if its hard to put back on?
Yes it should be very hard to bush back on.
Clamp the two together with Vice Grips and close the grips to force together.
Not sure how or why it came off if it is tight to get back on?
It may have a worn spot, so don't be alarmed if it pops off again.
hi all
managed to pop it back on without having to strip everything out if it happens again i now know what to do
