Panasonic KX-TGM420E not recording messages
7 Sep 2008
Kent
The base set has three other phones connected - it's on fibre broadband (Community Fibre). The phone is new and works well, but despite being set up correctly it refuses to record messages. We've tried the pre-recorded message which comes with the device and then I've recorded one myself. Both cut in after 5 rings and ask that you leave a message after the beep. But nothing is recorded. The light on the base set is set to record (but no indication of messages available) and there's a tape sign on the handset - does that mean that there are recordings somewhere? In every other way it's a great setup but we do really need to be able to get recorded messages. Any advice welcome!
With fibre broadband the "phone line" is really a VoIP service through the router, and most providers switch on their own network voicemail by default. My guess is that's what's answering after 5 rings: the caller hears a greeting and a beep, but the message goes to the provider's mailbox, not to the Panasonic, so the base never shows anything.
Two ways to sort it:
  • Set the Panasonic's ring count lower than the provider's (e.g. 2 to 4 rings) so it answers first. It's under the answering system settings, usually called "number of rings". Avoid "Toll saver" mode while testing, since it changes the ring count depending on whether there are new messages.
  • Or turn off the provider's voicemail. With Community Fibre that's done in your account or by calling them, and then the Panasonic will pick up.
Easy test: ring the number and listen to the greeting. If it's the one you recorded, it's the Panasonic. If it's a generic voice, it's the network mailbox, and your missed messages are probably sitting in there. The tape icon on the handset just means the answering system is switched on.
That's so useful - thank you so much. I was wondering why I wasn't hearing the message I'd recorded, (just some lady that sounds a bit like Holly talking to Kryton). The Panasonic instructions need a degree in technology and telecommunications to get through, but I'll persevere. Is there a quick way to get the CM messages without having to dial 1571 every time? I suppose all the controls/buttons will link to the Panasonic system by default.
Ha, Holly from Red Dwarf is spot on! That’s definitely the network voicemail, not your Panasonic.
And yes, you’re right: the buttons on the phone only work with the Panasonic’s own answering machine, so for the network messages it’s 1571 every time. You could save 1571 on a speed dial to make it a bit quicker.
But honestly, the easiest thing is to ring Community Fibre and ask them to turn their voicemail off. Then the Panasonic picks up, the light flashes when someone leaves a message, and you just press play. Before you do that, have one last listen on 1571 in case anything important is sitting in there.
Good luck with the manual!
All done - I'll quite miss listening to Holly (or is it Cruella?).
