Parallel Cables
1 May 2006
I've been doing a little research into parallel cables, for example 2 x 4mm's in parallel would be able to carry 50A, it would be easier and cheaper to use 2 x 4mm's instead of 1 x 10mm
But does anyone actually do this, obviously the technical problem with this is if a fault occured on one of the two cables, fairly sure this refers to cable group though.
Its just a thought
fattony said:
But does anyone actually do this?
Yes, the most common is called a ring final subcircuit.
And for the reason you mention is why some prefer radials.
the larger end of the scale quite often do this as running 2 150mm's is easier to bend etc than the equivalent size in single..
in fact they did exactly this at the birmingham indoor market...
( i know because we had to jack a cable ladder into place to support them after they were installed.. )
grouping factors will probablly kill most of the copper saving unless you take action to keep the cables apart from each other. This is more of a concern than with normal wiring because the cables will have thier load peaks at the same time.
I thought 4mm was pretty pricey stuff anyway, i'd be surprised if 2x4mm T&E was cheaper than 1x10mm T&E.
In summary the only reason i can see for doing this is mecanical handling issues with the really large cable sizes.
£6.10 per hundred metres cheaper for 10mm2
stem, I know what a ring final circuit is, my question was more aimed at showers and larger circuits, I should have made it more clear.
its worth bearing in mind about 2 x 4mm's instead of 1 x 10mm it may save you an hours drive to a CEF
I'm not sure its exactly what they had in mind when they wrote that regulation, but there is nothing to say it can't be used in a house on cables that small (though do check what cables the terminals in different pieces of switchgear/equipment can hold)
Do however go and look at 434-03-02, particulaly the second paragraph of it, it doesn't neccessaly mean you can't do it, but you probably should do the calculation. (and a very similar thing applies to the earth, no longer being a standard circuit, it should be 'selected or calculated')
Thats the problem with getting away from standard circuits, you start having to work stuff out... :wink:
