Plastic Plumbing Fittings
7 Nov 2006
Help!!!
Can anyone please confirm if grey plumbing pipe (called hep?) (from builders yard) is compatible with white easy fit plumbing fittings (from wickes).
I am a bit worried that they may not be suitable together and thought i had better check before nailing the floorboards back down.
if its the right size and it aint leaking its fine mate
remember to give the joint a tug to dig in the internal grips. If you don't the whole thing can pop off.
