Hoping for a bit of advice with a Potterton promax combi HE plus.
When using the shower, the hot water seems to stop for a short period then restarts after a minute or so. A few minutes later, same cycle.
Watching the boiler indicators, when running normally, the two LEDs are lit for the tap indicator and also that it's burning. When the water runs cold, both lights go out and water continues to flow, then it sorts itself and both lights start again and hot water returns.
The boiler was last serviced in Sept 2013, so will get it done again.
Any ideas if this is a common fault?
I don't know many local plumbers and I can imagine a service and diagnosing/repair is not a massively attractive job. I'd like to avoid being ripped off so any advice would be useful. I would use someone gas safe of course.
