Potterton Suprima 70 Advice
12 Jan 2006
Edinburgh
Boiler has no real problems good heat and hot water, never had to re-set it yet
One annoying thing about it is The boiler will fire down the pump will run for a few seconds then the boiler will fire back up it does this quite a lot, you can hear it in the morning and the constant stopping and starting is getting on my nerves
Also how often should i get it serviced and will a service make a difference, last time i paid to get my boiler serviced all the engineer did was remove the cover on my old vokera and hoover the dust took about 15 mins
You should get it serviced annually. The last one you had was NOT a service :shock:
Get a local recommended RGI in and he will check the boiler over for the stop starting at the same time.
