I need to pour SLC to a precise depth so that it perfectly matches some other surface that's currently higher (by 6mm) than the rest of the sub-floor. What is the best approach for this, should I just pour it as close as I can but ever so slightly too shallow, then smooth the tiny remaining step with a second application? Some 3mm vinyl is going on top so it does need to be pretty flat, I reckon.
I guess that if I pour too much and it flows over the top of the other surface then that's kind of ruined it, so best to pour too little perhaps.
What approach have you taken for this sort of thing?
while I'm here, what's a good way to fix wood down as barriers and dams to contain the SLC? Got to screw them in, pretty much? I tried some kind of super adhesive but that didn't hold onto the concrete at all. How about cardboard and duct tape, I bet that would hold alright.
Thanks!
Thanks!
