power showers
20 Jun 2009
can anyone advise?
is there much work involved fitting and installing a power sower
can instillation be handled by a fairly handy diy person
A power shower takes its supply of water from the cold water and hot water cylinder, which is not for the totally inexperienced DIYer since it should have a dedicated outlet taken from the cold water tank, and quite often needs a flange fitted to the cylinder to run the hot water supply from. A power shower cannot be used if you have a combi boiler.
An instantaneous electric shower takes it's water supply from the mains supply, which is within the scope of a DIYer.
Both need to be wired up by a qualified (part P approved) electrician.
What are you intending to have installed?
thanks dextrous,
it was an electric shower
its installed and working fine
i conected to mains supply like u said got a sparks to sort wiring
many many thanks
