- Joined
- 22 Oct 2011
- Messages
- 1
- Reaction score
- 0
- Country
Boiler fires up OK when hot tap is open, but will not fire up from room stat unless you turn the hot tap on. That is to say when the room stat demands boiler will only fire up if you turn hot tap on and off then will continue to work until the room stat switches it off.
Then it will not work again unless you do the trick with the hot tap again.
I noticed a thing called "Central Heating Sensor" in the manual but don't know what it does.
Hope you can help
Steve
Hope you can help
Steve
