I looked at a halstead ace for a client which was installed by someone who did not comission the instalation properly. I performed a powerflush which resulted in a huge amount of sludge being removed. This solved the problems they had but now i have new problems. When the hot water is switched on the heating also kicks in. When the hot water is switched off the heating carries on running for a few minutes and locks out.
Once the heating switches back on after about 5 minutes of waiting it will lock out almost instantly after the burner fires up.
I dont understand how the heating can work fine with hot water running but then not work at all on its own.
I can only assume this cant be the Fan, Diverter Valve, Pump, Overheat Thermostat or the Gas Valve but i could be wrong. Please help.
