Here is my story:
I have a combi boiler with 11 radiators.
Recently I removed one in bedroom 1 to redecorate, then refitted, bled and all worked OK.
In bedroom 2 I did the same, but having refitted and bled the radiator several times it refuses to get hot, and during bleeding, only water comes out - no air.
I have bled the radiator successfully with the heating off and both valves open. I closed off the input radiator valve and it bled fine. Then I opened the radiator valve and turned the TRV on the radiator output to the off position, and it also bled fine.
With both valve and TRV open, and all other radiators switched off, I turned on the heating. Both copper pipes either side of the radiator remained cold, so I started to bleed the radiator. After a while the input pipe warmed up, as did the top of the radiator and the water coming out of the drain plug. The output pipe and the bottom of the radiator remained cold, however. When I stopped the bleeding, the input pipe and radiator cooled down.
Obviously during all this I kept opening the valve on the combi to let more water in and keep the pressure around 1.5 bar.
The TRV appears to be working fine as the pin springs back out after being pushed in manually. The TRV has always been kept in the "fully on" position prior to the switching off and removal.
I have had 2 days of assorted attempts at fixing the problem and am now at the end of my tether. Please help!
