Looking for some help please. I have one radiator that just wont heat up. The rest of the radiators are working great. I have tried turning off all other radiators in the house but still no heat, not even to the pipe.
I have turned of both ends of the radiator opened the bleed valve and let it run dry, then opened one end (the outlet end) and opened the bleed valve,
let it run out, closed the outlet end off and opened the other end (inlet) opened the bleed valve and got a constant stream of water coming out.
So I know that the radiator is getting water in, but just wont heat up, the pipe going into the radiator does not heat up either.
The radiator doesn't have TRV.
Any help greatly appreciated.
