RADIATORS UPSTAIRS ONLY HALF FULL ## NO AIR##
23 Jan 2008
Warwickshire
I HAVE A PUMPED SYSTEM an have fit a new pump. i rained down and now the upstaires rads will not fill abovee half. the boiler only comes on for a few seconds then goes out. after 3 hours the rads upstaires gat half hot and downstaires all cold. PLEASE SOMEONE HELP.
p-s could it be the motorised vave stuck not letting water in.
regards andy 07889773049
The cold feed should be within 150mm of the open vent. Since one is 22mm and the other is usually 15mm and both go up it should be easy to identify.
For conclusive proof that it is blocked, bungee up your header tank valve and drain doen again. If the header tank is still full of water then it is blocked.
