ravenheat csi 85 combi
19 Sep 2007
Manchester
havin problems gettin ignition on ch and hot water, on my ravenheat csi 85 combi, fan and pump work , and red light comes on, any ideas please
Hi it does sound like the air pressure switch is not pulling in to operate the ignition, if you say the fan is working the next thing is the air pressure switch should pull in, it can be a blocked ventura or cracked pipes to it
It needs checking out properly and so does the p c b its not a job for the d i y as it involves removing the combustion chamber cover and that is a no go area
mick
