Hey Guys,
I am new to the Forum and joined to hopefully get some help with my diagnostics on my old boiler.
Here are the symptoms,
when the tap is turned for hot water there is no hot water available and the boiler is not firing. gas pilot on but not firing up to heat the water.
The central heating is working fine.
If the CH is on and i turn the tap for hot water the water gets hot for a period before eventually cooling right down to near enough mains pressure.
I was thinking after reading the owners manual and spending a bit of time reviewing other posts that this is a classic diverter fault.
I got a mirror and checked the operation of the plunger on the diverter and it does appear to be going in and out as the hot water tap is operated.
What's your thoughts?
Any help guidance would be appreciated!
Homozo
