RCD problems
16 Feb 2008
Cardiff
just changed my consumer unit to a split load, i put all the lighting circuits on the switch side and the ring on the RCD side but the down stairs lighting circuit is tripping the RCD, any help
lighting neutral connected to bar on wrong side of CU perhaps
or a borrowed neutral
You are aware that changing a CU is notifiable work under Building Regulations?
Thank you john D made the mistake before a long time ago of the neutral being on the wrong bar, decided to put a new feed in from the CU there being only 3 lights on the circuit and i am aware of the regs , thank you once again
