Hi I have the above in France and for some reason it is sending water out of the pressure releaf valve underneath
I stripped the boiler down and there is nothing to it inside, just basicaly an element an inlet for mains pressure and an outlet pipe which taked water from the top of inside of tank. Cleaned out but nothing seamed obvious.
still randomly releasing pressure.
Changed pressure release valve - no better
I do have a govenor on the mains so stripped that down but appeared ok( we have had severe frost -20 so though diaphram may have split)
But even when I turn the mains to only a trickle it still comes out of the boiler realease valve as though it is getting way too much pressure but there is not and I did not find a blockage within the boiler. sometimes it stops when you drawer off hot but sometimes it doesn't. Any ideas Cheers Tony
