Removing Gloss Paint
10 Sep 2006
Reently purchased new house and prevous owner had managed to spill tin of gloss paint onto gable end wall (facing bricks). Amy ideas how to remove this paint (been there for many years)
I would recommend their Kling Strip. I have been stripping thick layers of gloss paint from my kitchen walls. Kling Strip works very well but is expensive if you have a lot to do.
A cheaper option is this: put 1 litre of cold water in a bucket. Add 300g of caustic soda. Mix carefully with a long stick. Add and mix in plain flour until it reaches a wet porridge consistency. Apply fairly thickly to wall wearing rubber gloves and using a flexible scraper. Cut up plastic bags and stick them to the mixture to prevent it drying out too quickly. Leave it for a few days. You may find that it will all fall off, or you may need to peel it off. Then you might need to do a bit of scraping and lots of washing with lots of water. Be very careful as caustic soda WILL BURN YOUR SKIN (see fight club for example).
Good luck!
