Render
12 Jun 2006
Berkshire
I've been reading these comments boards for a while and most of you seem to know what you are talking about!!!
I am about to undertake a little DIY - need urgent advice from someone who knows!!
I am rendering my external wall. I understand the mix etc and intend to prime the wall with PVA but can someone tell me if I should use waterproofer and when??? Any recommendations for waterproofer?
Also any issues of rendering over pebbledash??
Thanks :D
Thanks :D
why are you using PVA?
to help with adhesion...?? Intention is to prime the wall (1:5) PVA, ;leave for 24 hours and do a render mix of 1:1:5 (cement, lime, sand).
Also some pebbledashed area almost impossible to take off so decided to render over it.
Any advice, gratefully received!!! ;)
I wouldnt use PVA externally for adhesion. What is the background? Your mix is too week for your scratch coat maybe 1-4 for your scratch with a waterproofer, then 1-1-5 for your top coat. ;)
cheers :)
background is brick/block...
any thoughts on rendering the p/d? scratch coat or just top coat?
