Can I check my understanding of something, and perhaps make a suggestion too ?
The "remove a radiator" article is quite clear, but I believe when it comes to putting the radiator back (or indeed adding a new one), things are different for open / sealed systems.
For a sealed system, when you turn the valve to reconnect the Rad to the system, I believe you also have to top-up the system using the filling loop. I believe care is needed to keep it between 1-1.5 bars while the Rad is filling.
SUGGESTION: this should be more explicit in the article, with a link to the following:
http://www.diynot.com/wiki/plumbing:filling_loop
If I've misunderstood anything, I'd hugely appreciate being told, as tomorrow I'm about to embark on this myself .... my boiler is quite new so I don't want to ruin it !! (I have a Worcester Greenstar with the filling loop very obviously at the front of it
Mike
Mike
