Hi,i have a glowworm flexicom 24cx.I have just replaced a faulty water pump(seized) and dec ided to test the system with the gas still turned off.I t went through its usual start up procedure and then F1 came up which was expected as there was no gas.The problem is i cant get rid of this fault code display.Is there a reset procedure i can use.Thanks for any help.
