I moved in a new home and trying to understand the set-up of my central heating system.
I have a heat only boiler (Ideal Logic Heat), two heating zones (with Danfoss room thermostats and one motorised valve each) and a closed hot water system (with it's own valve). The timer is a Danfoss single channel timer. The system is wired up as s-plan.
Now my question: what is controlling the hot water demand? As far as I understand the system has hot water priority, so the two heating valves close and the hot water valves opens, if the tank thermostat is flagging heat demand for the hot water tank. But what is controlling this? The boiler or is there somewhere a separate controller for that behavior?
In all s-plan diagrams I found so far, the timer has always two channels, one for heating and one for hot water. How does it work with a single channel timer?
Thanks for your help
