Sani flo WC, basin and washing machine
23 Jan 2023
Hi all,
Looking into getting a Sani flow. I have have found one online that supports WC, shower and Basin. Is possible that I can use the inlet for shower on the Sani flow for a wash/dryer machine instead?
Have a look at the specs on your chosen device- maximum input temperature and max litres/minute. Then see if they match your washing machine. It'll help if you have a longish (2 or 3 metres) run of waste pipe from the washer to the saniflo- gives a bit of buffer space.
I'm not a plumber & cannot say whether you can do what you want to or not, but I would suggest it would be really irritating that the saniflo fires up every time the machine drains and refills through the wash cycle. Also it will raise your electricity bill a fair bit if you use it regularly.
My Saniflo is able to take a shower (although I don’t use it as such) so they are made to run on/off constantly with highish water temperatures. As said, may need a bit of a buffer if used with a washing machine.
