Hi all, I have been to look at a faulty sanivite in a cellar, it is trying to pump all the time, it has a sink and washing machine plumbed into it, also a condensate from a boiler, I disconnected the discharge pipe and this did not seem blocked as I took it apart not a lot of water came out,does this suggests its not blocked? also put it back together and switched it on, and ran some water from the sink and it started to pump cut off then starts again repeating this cycle and does not stop, it would do this untill switched off at switch again, I am going to check the horizontal run to check fall and make sure its not blocked at soil connection, but as i said earlier if it was blocked surely vertical pipe would hold water? any help/advise appreciated thanx,,
