Hi guys,
Long time lurker, first time poster.
I have a manky old Sauiner Duval boiler (non combi) running an open system - old skool, inherited in old house. Has always worked OK (if seemingly inefficiently) but a problem that I've come back to yesterday leaves me scratching my head.
When told to turn on by the programmer, the boiler autoignites as normal and runs for maybe 25-30 seconds, then the noise it makes changes, almost as if you were boiling a kettle dry - then it cuts out (I guess a thermo protect) and takes 20 minutes before it will fire again. Clearly this isn't enough to heat a house or make hot water.
I've bled maybe 6 litres from the lowest point, bled all rads (no air) and checked the expansion tank but am now stumped. Would appreciate any ideas for what is making this happen.
Thanks a load.
Jaz
Thanks a load.
Jaz
