Sewage/drains smell in bathroom
26 Feb 2013
Essex
Hi all
We are renovating our downstairs bathroom and have removed sink, toilet and shower and floor.
I have put multi-fit caps over the 32mm/40mm waste pipe ends (having removed the traps) and a 110mm plug on the soil pipe 90 degree bend that used to go into the toilet.
The soil stack in the corner is extended upwards to the ceiling as the previous owners had plans to install an ensuite above, and tried to future proof accordingly.
The top of the soil pipe is flared, has a pushfit opening which is currently occupied by a screwed access cap.
Even with the caps (during renovations), there seems to be a constant smell of sewage/drains/poop in that bathroom, ever since we removed everything, and I can't work out where it might be coming from.
We called Homeserve as they had a "smelly drains" option, they were not forthcoming on arrival, to put it lightly.
A few online similar threads have suggested a Durga/AAV at the top, or the seals on the push fit connections are old and letting gas in. Others have suggested it's dried out during renovations, so put some water down it.
I don't want to ignore it and close everything up, and find that there's still a smell with a finished bathroom.
Any suggestions from you lovely folk would be greatly appreciated.
Thank you for your help in advance!
See pictures for reference.
There's a roof vent downstream, the vertical soil you see in the picture is capped off with a pushfit screw cap.
@HERTS P&D thanks Andy - any advice on how to identify which ones are not air tight? I could re-cut the pipes and reseat the rubber seals.
Hi all
That white one is open ended
Apologies the pictures are old, it was just to show the locations of the pipes etc. As mentioned on the post, I have put multi fit caps on the two white ones. Thanks Andy and CountryFan.
If I were to install an AAV, would it be one of these? (see attached)
Thanks!
It's not an AAV at present, it's just a screwed access cap like the one attached
Fit Compression Waste Caps to the Bath and Basin wastes, and if you're happy the WC Branch is adequately sealed then give it a couple of day and see if things improve. If they don't, I'd suggest a smoke test in the external drains, that should show up any leaks into the Building.
