Should I put 2 channel smart relay outside or in my house?
23 Jan 2012
Essex
Afternoon all.
At the moment, I have an old-fashioned halogen security lamp that is faulty (the PIR doesn't work properly) and it uses too much, anyway.
The switch for the light is on the wall and the switch therefore has three sets of wires coming into it - two sets are inside (that is, continuing the lighting circuit) and one that goes through the all to the halogen light.
Rather than replace the existing light with a new LED version, I want something that my Smart Home can control. Plus, I want to have two lights that I can control, rather than one - one for the back of the house and one for the side.
I know you can get smart flood lights but it is cheaper to buy regular ones and just control them with a smart relay.
I therefore have two options:
1. Remove the existing lamp and connect the wire to a 2-channel smart relay on the outside of the house in a junction box and then run the lights either side of this junction box.
2. Put the 2-channel smart relay where the current switch is, on the inside of the house, and run two wires (rather than one) through the wall.
Is there any real difference between the two methods?
My instinct is to go with the latter as relays are probably better within the house, wherever possible, and more easily accessible if I need to physically override the relay for some reason.
What do you think?
Thank you.
One other quick thing, whilst I think about it - my original plan is to have a lowish watt floodlight down the side of the house (say 10w) for security but then have a much more powerful light (perhaps 50W) to help illuminate my back garden.
Is a 50W single light any better than, say, two 25w lights? Electrically, there should be no reason why I cannot connect two lights to a single relay but I am not sure whether having two lights, spread out, would give better coverage or not.
I have bulbs, relays, and switches, and the main point is what they do after a power cut.
In the main my bulbs will light when power is resumed, which means turning the light switch off then back on, will turn on the lights.
I only have one relay, and it seems to default off, not really had enough power cuts to notice.
Wall switches, the Energenie ones default off, but the TP-Link ones (Tapo) are battery powered, so do not change state with a power cut. Also the both do not require a neutral, so the Energenie ones need a load of 5 watt or more, removing a bulb with auto turn them off. Where the Tapo version I have one powering an outside light with a PIR and it does not mind the PIR turning on/off.
I have in all 9 outside lights, 2 are still manually switched, rarely used, 5 are screwed to side of the house, one is on a pole next to my pond, and one on the outside of my shed, the one on the pole has a colour changing bulb, I change this to green for Halloween, and colour changing for Christmas, so having the smart bulb works out better, one corner of the house, I have a Wiz smart bulb, which is set to slowly turn down then off, so it gives a warning it is going to switch off, the smart adapters and switches from Tapo allow the setting of dusk and dawn, so outside light set to switch off at dawn, as can many smart bulbs. But the Tapo also allows it to switch on one hour before dusk, I use that for the living room lights, and on Monday, Wednesday and Friday (days milk delivered, it turns on at 7 am, and off 1 hour after sunrise, this means in summer it still turns off as sunrise +1 is not before 7 am, I think, not checked, but due to varying features, I have moved socket adaptors around, the Energenie smart devices I got first, and they are today no where near as good as the TP-Link (Tapo) units, but some are now around 7 years old, and things have moved on. Energenie only had three on/off slots, today have not noticed a limit to new smart stuff.
I have 5 smart hubs, one zigbee is the Wiser central heating hub, so maybe should not count that? The TP-Link when I started had different hub for Tapo and Kasa (latter the TRV heads) now they are combined, but they also double as my door bells, the second zigbee hub was cheap, and I have the old Energenie hub which is the odd one out as needs hard wiring to the router.
So the wifi from the router needs a lot of power, the wireless from the likes of zigbee use very little power, so having a hub means less stand-by power is used, every mains powered device acts as a relay for other devices with the zigbee system, where as with a light bulb advertised as not needing a hub, in general it uses more power on stand-by.
Apps like smart life can work with both hub equipment and direct, and a lot of equipment can be set to use Alexa or Google Home, I use google Home, which means what ever make, I can control them with the same app, and my Nest Mini speakers can work them with voice control.
So before setting off home when on my own, or when getting near to home when wife is driving, I turn on outside lights with my phone in the google home app, one click turns on all makes, and once home, hey google turn off outside lights, turns them all off again.
To me the problem is there is no one device or make does all, even Tapo socket adaptors there have been around 5 models and working out which you want is not always easy.
Sorry you posted while I was writing,
this is three bulbs, one on each corner of house, and one on shed, all around the 12 to 15 watts at night. It is the trees and shed shading which needs the three lights.
For security I am better with no lights, some 5 foot shear drops if one walks in the wrong place, one would need to be brave to walk around my house at night, and falling 5 foot does tend to make some noise.
I have a lovely 70 watt metal halide lamp from years ago which from my bedroom window can light the whole of the back garden, but it will also light house at bottom of my garden garden the main road, and houses other side of the main road, so I tend not to use it.
Sorry you posted while I was writing, View attachment 427288 this is three bulbs, one on each corner of house, and one on shed, all around the 12 to 15 watts at night. It is the trees and shed shading which needs the three lights.
Thanks very much for this - really helpful.
Just looking at your photo, three 12-15 watts, spread around seems to really work well for you - you can certainly see everything in your garden very clearly.
Perhaps, based upon this, a couple of 20w floodlights, spaced along the back of my house, is the way to go. Thinking about it, I would prefer a gentler light over the whole garden, rather than a very bright area in the middle with shadows down the sides. Perhaps I can get a couple of fully rotational mounts (i.e. left and right, as well as up and down), so I can do a some experiments on how best to cover everything.
Back-up-power.jpg I used my jump starter with a standard lamp to work out what would work, I did the same to work out if the wireless controls would work, and so I was sure the light on the shed would work OK before I fitted it.
I took the SWA cable to a socket on side of shed, so it goes into the shed quite high up, I thought this would stop mice etc. However, after catching mice my cats helped into the house, and releasing them outside, I realise they can climb brick walls with ease.
But should still stop moles, my cats seem to think they should be transported indoors into the warmth, I thought cats should keep mice, birds, moles etc out of the house, clearly they have other ideas.
