simple question
20 Jul 2014
Durham
hi just a simple question,flat garage roof 6.63m long x 5.28mwide , would a 3" drop from side to side suffice to get rid of water. :?: :?: :D
Three inches seems a bit low - you might get ponding when the joists dry out and twist slightly; - 5 - 6" would be better on a roof of that width.
Simple answer
Minimum fall for flat roof is 1 in 80 over 5.280 = 66mm
Suggest you go 1 in 60 over 5280 = 88mm.
That is a hell of a span for flat roof. What size joists you using, or have you got a central support?
Regards opldun
hi joists 9 x 2 two rows of herringbone straps internal is 4.66 50mm cavity wall
:lol: :wink:
