Hi, I want to chase the hot and cold (both 15mm) into the corner of a kitchen exterior wall.
I think I read somewhere that you cant plaster directly onto the pipes as it eats into it over time, is that correct ?
Im not too bothered about plaster cracking slightly as it will mostly be hidden by tiles and wall unit.
not sure if it needs insulation but Id rather not chase too big a channel to accommodate that.
is plastic or copper best to use ?
