sizing boiler. And hw req.
18 Mar 2010
Durham
Instead of picking the highest possible output boiler in the range, to get the boiler with the best Hw flowrate.
Is there a better way to choose the correct size boiler, which will give good hw flowrate
Work out what kind of hot water delivery you REALLY need and size the boiler to suit.
Bear in mind that the bigger the boiler the bigger the gas pipe.
No point putting 42kw of output when you have a single shower and/or 8 l/min of incoming water.
You need to measure your incoming cold mains water pressure and flow rate, this will determine the Kw output for hot water that you can have.
