Sky dish location
Maybe also have a look at a 'transparent' dish. You will still be able to spot that it is there, but isn't as noticeable as a normal 'grey' dish.
Hi guys, thanks for the reply. the options still will not work. theres is no fences around the property so this dish would need to be high up because of the trees etc :(, Has anyone used the window method?
Oh, you've just discovered trees? How high does the dish need to be to clear the trees? Are you certain that it can't see the satellite at ground level? (You'll have to look up the elevation for your location, the compass bearing and work out the angle between the top of the trees and the ground.)
Nope always seen the trees lol, I was thinking can I get a shower curtain pole or something stronger and wedge it between the window, will that keep the dish in place lol?
