I have the above dishwasher. Installed it the other day, connected the water inlet and outlet hoses fine. Water supply in seems fine.
Stuck it on a simple wash cycle, however after maybe a min or so error code 6 flashes up, which apparently means the machine can't pump water out from the tank.
Does this mean i need a new pump or should i be checking anything else?
thanks for you help....in advance!!
Cheers
Donald
Cheers
Donald
