- Joined
- 22 Aug 2004
- Messages
- 130
- Reaction score
- 2
- Country
Can anyone out there recommend a reliable solar powered pump - I intend to power a small fountain perhaps 2 metres or so above a small (half oak barrel) so the water only needs to be pumped up to the water feature and then trickle back to the barrel?
I am keen to minimise the use of electicity and as I will only be sitting outside and appreciating the sound of water when it is sunny it seems an ecofriendly thing to do.
I have been told that the solar panels that float on ponds do not work because they quickly get covered in algae - I intend to mount mine high on a trellis.
What technical stuff in terms of voltage might I need to know? Can I bodge one together using exisitng submersibles and solar panels available for other uses?
Any help greatly received
Steve
Steve
