- Joined
- 3 Oct 2012
- Messages
- 44
- Reaction score
- 0
- Country
We live in a 1920s three bed end of terrace. Walls are solid. The hall gets very cold in the winter. We made things worse when we stripped the wallpaper and re-skimmed a couple of years ago. Stairs are fairly narrow as it is so we only have about 15mm to work with. We already have a big double rad. Only options I could think of are:
10mm Marmox insulation board (possibly 12.5mm) or 4mm Erfut Wallrock insulated wallpaper.
I suspect the first option will cost twice as much as the second.
I asked the same question last year. Did not end up doing anything to the wall, but did replace the front door with a composite one. Also cut out all the drafts. Wondered if there are any new products on the market that are worth considering?
Also, if I was to go with the Wallrock option, how easy is it to get off, if, after a couple of years I decide to try something else.
Grateful for any advice.
