system seems air locked
15 Jul 2011
having turned off my central heating , and using just hot water my system has stopped giving me hot water. I have a grundfos alpha which runs continually into the cistern, but does not give me hot water. the pump sounds noisy but i can get a couple of drips out of the baring when I remove the cover. I cannot get any pressure to bleed my upstairs radiators when I put the central heating on . ps the cental heating boiler and cistern is upstairs. help!!!. pps this is from an old geezer who can peen lead pipes and wipe a joint and now needs someone to wipe my bum (not literaly)
have you ever cleaned your system out
also check the air seprator with magnet see sludge up
also are u ex corgi if so try join cc we do take the miky a lot their but any future problem we can go into more detail
This system is not 3 years old yet, each radiator taken outside and power flushed put back in dosed with x800 and finally was topped up with x100. The boiler is anicos he18 . confession where is air seperator? Further to your comment about me changing horses I cut my teeth on clipping mats on fire unless the burst back boiler had put it out
air seprator should be on flow and return pipe going to the f and e
and if you cut your teeth should get false ones
