Terminal blocks -- which ampage?
18 Oct 2005
London
Hi all,
I know this'll sound terribly naive, but never mind...
I need to slightly extend the electrical cables from a household ceiling rose to reach the terminals of a new light fitting. I intend to use a terminal block to achieve this. Two questions:
1.) Is this a safe/sensible strategy?
2.) What minimum amp rating should I gun for the terminal blocks -- 3A, 5A, 15A, 30A?
Ta,
Harry.
5A would be correct
However most modern ceiling roses include four little connection blocks in them, you may find that if you fit a new rose you don't need a choc block.
(?do people still call them "roses" ?)
Thanks for that... it's quite an old fitting, and it doesn't have any spare terminals as such.
Btw, I'm not sure what else to call it apart from a ceiling rose -- is there a more modern term?! And I'm guessing 'choc block' is the more modern word for terminal block? I must be getting old...
There are various ideas for calling it a choc-block, my personal preference is that the nylon connector blocks look a bit like a piece of Cadbury's Dairy Milk, divided into squares.
Didn't they used to be black or brown instead of see thru as they are now - hence they did look like chocolate - but tasted pretty naff
Now I think of it, you're right - but the brown ones weren't as widely used then as the translucent or white ones are now.
But so much tastier...and if you were lucky you'd get a golden ticket to Wonkas factory inside.......ok maybe not
