I have a Potterton Netaheat boiler and Potterton Ep2000 controller.
The Central Heating won't work on it's own - I've tried using the timers, 24 hrs and over-ride function. I can hear the thermostat click when I hit any of these functions but nothing happens.
However, if I set the HW to 'once' or 'twice' or 24hrs and then put the CH to the same setting, the boiler fires up and I have heat.
I can't seem to control the temperature using the thermostat.
Since this problem started, my work-around used to work if I pressed the 'over-ride' HW button and then the 'over-ride' CH button. However, I have noticed that the 'over-ride' function no longer works for either CH or HW.
The diverter valve appears to be moving as follows:
From turned off to HW on, the valve moves and HW's on
From Turned off to CH on, the valve moves but no CH
From turned off to CH/HW, the valve moves and we have both.
Can anyone help?!
Thanks,
Lesa
Can anyone help?!
Thanks,
Lesa
