Hi there
I've brought this subject up from time to time over the last 18 months, so apologies for bringing it up again. I'm having major home refurb and extension work done and plan to have a new hot water and ch system fitted.
When I first brought this up things were at the planning stage of the build. Now the build is well under way and I really need to make my mind up and I'd really appreciate some final help.
My main concern is not the heating side of things but hot water, ie running a number of showers at the same time.
1) The house will be approx 3500 sqft over three floors, but the third floor is only about 350 sqft
2) There are five shower rooms
3) I'm pretty sure my supply pipe is 22mm, or at least that is the size pipe that appears from underneath the floor and leads to the stop cock.
4) There is a prv just after the stop cock set to 3 bar. I have inserted a pressure meter into the prv and I can measure up to 5 bar if I adjust the prv to its maximum
The pressure drops from 3 to a measured 2 bar when the taps are opened. However even when the taps are open I can increase the measured pressure up to 4 bar by opening up the prv.
My flow rate at 3 bar is 18l/min and this increases to about 26l/min at 5 bar.
In terms of hot water my requirements are to be able to run two showers comfortably at the same time (assume 15l/min each) and be able to open a sink tap. It's essential I can do this without any problem.
I've been 'offered' three different systems by three different plumbers to provide this (btw they have all said it would be a good idea to upgrade the supply pipe on my property to 32mm)
1) One or two system boilers + 300l unvented cylinder + break tank with booster pumps
2) One or two system boilers + 300l unvented cylinder + accumulator
3) One combi boiler to supply hot water to the kitchen and ch to ground floor and then system boiler + 300 litre unvented cylinder to supply hw and ch to the upper floors. This guy doesn't see the need for accumulators or break tanks/booster pumps but wants not only the supply pipe on my property boundary upgraded but also the mains feed upgraded on the road (by Thames Water)
phew!
I'd appreciate your thoughts
Many thanks
phew!
Many thanks
